Now i have updated to 4.5.49 and same problem…the pdfs send per mail are corrupt. I also put a ApiKey from PhantomJS in the env file, but same…and the test didn´t work also.
Please what can i do? It is a strato hostet websever, so i couldn´t install PhantomJS.
Thanks, yes, but it is a strato hostet server, so could not insztall anything. And for years it works, but after 4.5.47 it didn´t anymore and i changed nothing beside to update???
Where can i get this info?
If all else fails you can try changing the code to prevent SSL checks.
The link is broken??
