Hi there,
Where can i get document page for Dynamic variables refers ?
I want to set the date range for the invoice 18-2-2018 to 17-5-2018, How can i do it ?
Thanks !
Hi there,
Thanks !
We support using $pageNumber and $pageCount in the footer.
Can you clarify? Maybe you can set it in the invoice terms or notes.
Thanks for reply !
I meant i need auto create recurring invoice with 3 months period date(XX-X-20XX to XX-X-20XX) in the invoice content.
Any dynamic variables can i use for it ? Wheres url for listing all variables invoice ninja support ?
Thanks !
If you click the question mark next to the frequency select you’ll see the supported variables.
