After installing ssl certificate documents stopped loading preview in setting but when i enter preview in next window image loads perfectly fine.
are you loading https:// over port 7000 and not 443?
yes im using port 7000
We already use port 443 for other domain. But it shouldn’t be any problem.
Plus we don’t want to host invoice system on port 443.
[2022-07-27 10:53:09] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:"[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#0 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(257): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /var/www/invoiceninja/app/Http/Controllers/DocumentController.php(126): file_get_contents()
#3 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(145): App\Http\Controllers\DocumentController->App\Http\Controllers\{closure}()
#4 /var/www/invoiceninja/vendor/symfony/http-foundation/StreamedResponse.php(93): Illuminate\Routing\ResponseFactory->Illuminate\Routing\{closure}()
#5 /var/www/invoiceninja/vendor/symfony/http-foundation/Response.php(375): Symfony\Component\HttpFoundation\StreamedResponse->sendContent()
#6 /var/www/invoiceninja/public/index.php(61): Symfony\Component\HttpFoundation\Response->send()
#7 {main}
[2022-07-27 10:53:26] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:03:48] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:04:16] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:09:02] production.ERROR: Attempt to read property “invoice” on null {“exception”:”[object] (ErrorException(code: 0): Attempt to read property “invoice” on null at /var/www/invoiceninja/app/Http/Controllers/ClientPortal/InvitationController.php:92)
#1 /var/www/invoiceninja/app/Http/Controllers/ClientPortal/InvitationController.php(92): Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /var/www/invoiceninja/app/Http/Controllers/ClientPortal/InvitationController.php(58): App\Http\Controllers\ClientPortal\InvitationController->genericRouter()
#3 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ClientPortal\InvitationController->invoiceRouter()
#4 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#5 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(261): Illuminate\Routing\ControllerDispatcher->dispatch()
#6 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(204): Illuminate\Routing\Route->runController()
#7 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(725): Illuminate\Routing\Route->run()
#8 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#9 /var/www/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#10 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle()
#11 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#12 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#13 /var/www/invoiceninja/app/Http/Middleware/SetInviteDb.php(83): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetInviteDb->handle()
#15 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#17 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#19 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#21 /var/www/invoiceninja/app/Http/Middleware/SessionDomains.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SessionDomains->handle()
#23 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#25 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Session\Middleware\StartSession->handle()
#26 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#28 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then()
#30 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(703): Illuminate\Routing\Router->runRouteWithinStack()
#31 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(667): Illuminate\Routing\Router->runRoute()
#32 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(656): Illuminate\Routing\Router->dispatchToRoute()
#33 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch()
#34 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#35 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#37 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#39 /var/www/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#40 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle()
#41 /var/www/invoiceninja/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#42 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle()
#43 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle()
#45 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#47 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#48 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#51 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#53 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#55 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then()
#57 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#58 /var/www/invoiceninja/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#59 {main}
[2022-07-27 11:10:04] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:10:13] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:10:14] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:10:15] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/tnxZdfj9e2ZUmPppmJSGfAj7les9S8TUHSKyXfsY.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:39:09] production.ERROR: file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:39:20] production.ERROR: file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:39:21] production.ERROR: file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:39:22] production.ERROR: file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:39:35] production.ERROR: file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused {“userId”:1,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/m1PSJp8OqxP5Vb6vR62X4YZDuaQgVMaXPyPbwwjN.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
[2022-07-27 11:57:58] production.ERROR: file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/vC6QQ7jCzIj9bdhSq5LCGMdWtBnHSDl2dIZkJxOG.png): Failed to open stream: Connection refused {“userId”:2,“exception”:”[object] (ErrorException(code: 0): file_get_contents(https://invoice.nex-it.pl:7000/storage/uVNlLjgn64I6iOUf5LMJeN4DFuFAxQ1G/documents/vC6QQ7jCzIj9bdhSq5LCGMdWtBnHSDl2dIZkJxOG.png): Failed to open stream: Connection refused at /var/www/invoiceninja/app/Http/Controllers/DocumentController.php:126)
#7 {main}
Here is my laravel log
