Documents field in Clients
Hi -
It’d be great to have a “drop files” field in clients tab.
Can you include this feature in a future release?
Regards,
Thanks for the suggestion, we’ll keep it in mind for the future.
Good morning, I’m a newbie, is there a way to delete or modify the fields in the add clients section? I tried to search for the page responsible for this form but couldnt find it, thanks in advance.
You could use custom fields on Settings > Invoice Settings
Another option is to create a custom module to add the fields.
If you modify the code you’d need to reapply the changes with every update.
