I wanted to use InvoiceNinja self hosted with docker. And I have managed to get it to run so far that the log looks good. But the part I haven’t managed to achieve is to actually connect to it.
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
Nothing to migrate.
2021-03-28 00:24:18,277 WARN For [program:php-fpm], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-03-28 00:24:18,278 WARN For [program:scheduler], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-03-28 00:24:18,278 WARN For [program:queue-worker], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-03-28 00:24:18,280 INFO supervisord started with pid 1
2021-03-28 00:24:19,281 INFO spawned: 'shutdown' with pid 79
2021-03-28 00:24:19,283 INFO spawned: 'php-fpm' with pid 80
2021-03-28 00:24:19,284 INFO spawned: 'queue-worker_00' with pid 81
2021-03-28 00:24:19,285 INFO spawned: 'queue-worker_01' with pid 82
2021-03-28 00:24:19,286 INFO spawned: 'scheduler' with pid 83
READY
[28-Mar-2021 00:24:19] NOTICE: [pool www] 'user' directive is ignored when FPM is not running as root
[28-Mar-2021 00:24:19] NOTICE: [pool www] 'group' directive is ignored when FPM is not running as root
[28-Mar-2021 00:24:19] NOTICE: fpm is running, pid 80
[28-Mar-2021 00:24:19] NOTICE: ready to handle connections
Schedule worker started successfully.
2021-03-28 00:24:20,457 INFO success: shutdown entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-03-28 00:24:20,457 INFO success: php-fpm entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-03-28 00:24:20,457 INFO success: queue-worker_00 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-03-28 00:24:20,457 INFO success: queue-worker_01 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-03-28 00:24:20,457 INFO success: scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Execution #1 output:
Running scheduled command: App\Jobs\Util\SchedulerCheck
Does the docker contain a webserver? If not - how exactly can I connect it to one? I am using unRaid as my Host. That’s making it more difficult to follow the instructions laidout in the github unfortunately. Could I map some folder of the invoice docker to my local hard drive and map nginx to the same and make it work? I really am at a loss here.
