Version
v 5.12.6
Environment
Docker
Describe the bug
Is there a way to customize the cronjob execution? Currently it runs every hour. I would like to run it every 5 minutes.
Expected Behavior
Some option maybe .env to edit cronjob
v 5.12.6
Docker
I’m not sure I understand, by default the schedule cron should run every minute.
Hey, okay thanks for this information. But new scheduled emails, yearly send out will be send out one hour of creation. So I think that the cron inside the docker image only runs hourly.
Any option to adjust that?
Thanks, understood. I don’t believe that can be adjusted, feel free to create an issue on GitHub to request it.
