I’m following the instructions outlined in the dockerfiles repo to spin up a new instance of InvoiceNinja using docker-compose, and the application is failing while running a db migration:
app_1 | 2022-07-25T23:46:34Z [INFO] [Entrypoint]: Initialising Invoice Ninja...
app_1 |
app_1 | INFO Configuration cached successfully.
app_1 |
app_1 |
app_1 | INFO Caching the framework bootstrap files.
app_1 |
app_1 | config ........................................................ 34.68ms DONE
app_1 | routes ........................................................ 76.90ms DONE
app_1 |
app_1 |
app_1 | INFO Running migrations.
app_1 |
app_1 | 2022_07_18_033756_fixes_for_date_formats_table_react ........... 7.24ms FAIL
app_1 |
app_1 | In 2022_07_18_033756_fixes_for_date_formats_table_react.php line 17:
app_1 |
app_1 | Attempt to assign property "format_moment" on null
app_1 |
app_1 |
invoiceninja_app_1 exited with code 1
Not sure what’s going on here. Any clues?
