Design pagination
The content of a page overlays the footer.
How/where can I define a page break that starts n pixels before the beginning of the footer?
It may help to increase the page’s bottom footer/margin.
That is also my guess, but where can I set this?
You can add it using a custom design.
I realise that, but where exactly does it have to go in the custom design?
grafik
The “includes” tab which is the last one.
Can you please give me a little more information on how/where exactly what needs to be entered. I have attached the content as a txt file.
includes.txt (7.2 KB)
Try adding it inside the body tag towards the top.
body {
  margin-bottom: 40px;
  padding-bottom: 40px;
You mean here:
This does not seem to work according to the preview.
That’s correct, @david do you have any suggestions?
In the footer class, you’ll want to change
<div class="repeating-footerx" id="footer">
to
<div class="repeating-footer" id="footer">
you’ll then be able to control the reserved space for the footer in the includes section by modifying
.repeating-footer,
    .repeating-footer-space {
        height: 10px;
And setting the height to the appropriate amount.
Where exactly does “repeating-footerx” need to be changed?
I have found the line in 8 files:
resources/views/pdf-designs/elegant.html
resources/views/pdf-designs/creative.html
resources/views/pdf-designs/playful.html
resources/views/pdf-designs/hipster.html
resources/views/pdf-designs/business.html
resources/views/pdf-designs/clean.html
resources/views/pdf-designs/plain.html
resources/views/pdf-designs/tech.html
I believe David was suggesting to make the change in the custom design.
Where do I have to change the class <div class="repeating-footerx" id="footer">?
I believe it should be in the body tab, which design is your custom design based on?
I can’t remember whether I used a template or created it from scratch.
Above I have inserted the content of includes as a file. There is neither a <div class="repeating-footerx" id="footer"> nor a <div class="repeating-footer" id="footer">.
I have now changed repeating-footerx to repeating-footer in all 8 files and entered the following under includes:
.repeating-footer,
        height: 10px;
Unfortunately, none of this helped.
Would you please tell me exactly where to put which entry.
