Hey there,
Is there a way to actually delete invoices. Right now the remove feature simply tags invoices to prevent them from being visible without specifically filtering for them. Sadly, they are still visible in the client portal.
Is there an in-app way of completely removing them? If not, instructions to manually remove the data from the database (and possibly files) would be appreciated.
Thank you!
