ysintos
October 29, 2017, 11:42pm
1
I set the default tax in settings but when i create an invoice that defeult tax is not preselected.
It is not something hard to select it, but the problem is that most of the times i forget to set it and the tax on the invoice is set to null-none-zero.
Anyone has the same issue ?
October 30, 2017, 3:46am
It seems to be working in my tests, the default tax selected on /settings/tax_rates is selected when creating a new invoice.
Are you using invoice taxes or line item taxes?
I am using invoice taxes.
Unfortunatelly it is not working on me
October 30, 2017, 4:41am
4
Can you check you’re using an exclusive tax rate, we don’t support using inclusive rates as a default.
What is an exclusive tax rate and what is the inclusive one ?
October 30, 2017, 5:19am
6
You can see an explanation on /tax_rates/create
October 30, 2017, 7:29am
8
Do you see the same problem on invoiceninja.com
9
I’m assuming you’re referring to the self-host web app.
ysintos
October 30, 2017, 9:14am
10
Exactly.
I can’t understand why this is happening.
Do you want meto give you the credentials to check it ?
October 30, 2017, 9:17am
11
Can you post or email us a screenshot of your settings on /settings/tax_rates
October 30, 2017, 9:37am
13
Thanks, maybe it’s a localization issue?
ysintos
October 30, 2017, 10:02am
14
I don’t know how to check it.
October 30, 2017, 6:13pm
15
Does the problem occur if the tax name is in English?
Also, do you see the problem on invoiceninja.com ?
ysintos
October 30, 2017, 8:11pm
16
If i change the name of the tax to English, the problem is gone.
So i guess it has to do something with the language.
October 30, 2017, 8:45pm
17
Great, that’s helpful to know. Can you post an example tax rate name you’re using.
October 30, 2017, 9:12pm
19
