Hey guys, wondering if there’s a way to default new contacts into a group? The vast majority of new contacts fall into one group, while few and far between fall into a second group. It would be nice to not have to select a group for every single new contact, instead just having to select a group occasionally.
Thanks for quick response! Payment gateways are set based on group. If I don’t group contacts into the first group, the payment gateways are all out of whack.
If I archive any gateways in company level, they also go away within group settings. Therefore, I don’t know how to set company gateways (current default) to match picture in first group, without losing the gateways I’ve set for the second group.
Have you tested the client portal as a client? I believe duplicates shouldn’t be shown, if you sort the default higher in the list the duplicates should be hidden.
