Default Footer
I know you can save a default footer, but would it be possible to have a default footer for individual clients? This would be amazing!
P.S. I am self hosted and white labeled… Is there a way I can donate to Invoice Ninja? You guys are doing such a superb job and deserve it!
Let me know!
You could add a custom client field called ‘Footer’ on /settings/invoice_settings#client_fields and then use $client.customValue1 as the footer value.
Thanks! The best way to help is leave us a review on Capterra.
https://www.capterra.com/p/145215/Invoice-Ninja/
Thank you for your reply. The issue with that is at the moment only two custom fields can be created, and we’ve already created two custom fields. This is why I was wondering if it can be added as a feature in the future. Or maybe allow us to add more than just two custom fields?
And I’ll definitely leave a review on Capterra!
Once again thank you for your reply!
It’s possible we’d add more custom fields in the future, you may want o create an issue on our GitHub repo to track the request.
https://github.com/invoiceninja/invoiceninja/issues
Awesome, I’ve posted the feature request over on GitHub! I actually have another feature I’d like to request as well, I’ll request it over on GitHub as well.
Thank you very much. :slight_smile:
