I’m looking for a way to make certain things appear only on quotes (not on invoices) and to have other custom things appear/not appear.
I noticed there is javascript in the invoice_designs, but it doesn’t seem to be triggered in any way.
Does anyone know how exactly this part works. I can’t find any documentation about it.
Sorry, we don’t support using Javascript in a custom design.
I was actually trying to modify one of the existing templates, because they are close to what our customer needs. But I need to modify it through Javascript.
I updated the javascript in the invoice_designs table and purged the cache, but it doesn’t change anything.
Is there documentation on how this part of the system works ?
- The designs are stored as JSON, not JavaScript.
- You’d need to change the files in storage/templates/ and then run
php artisan db:seed --class=UpdateSeeder
to update the designs. - Here’s the JavaScript which creates the PDF, you’d need to run gulp after making any changes.
https://github.com/invoiceninja/invoiceninja/blob/master/resources/assets/js/pdf.pdfmake.js
So there’s no way to make modifications beyond what’s in the JSON ? In that case the javascript column in the invoice_designs table is no longer being used ?
The pdfmake column in the invoice_designs table is used, the javascript column is not (we used to support two PDF rendering engines).
