Is it possible to add custom fields for addresses, both company and client ?
Yes, you can configure custom fields on Settings > Custom Fields.
I’m on v5.2.5 and there’s only Client Field and Contact Field in Settings > Custom Fields > Client.
I’m not sure, the first tab should be ‘Company’
When I create a new client, I find it hard to fit the address into the default fields. That is in New Client > Billing Address & Shipping Address as well as Settings > Company Details > Address. It would make things easier if I can create custom fields that match the address format for my country.
Maybe use multiline custom text fields?
Seems a bit hacky. The address appears as one long line without newlines. I guess I’ll try to make the default fields work.
