Trying to import expenses from a CSV file but the date is imported in the wrong format: the days and months are swapped. I have the Date Format set to dd/mm/yyyy under Localization Settings but it doesn’t seem to apply when importing CSV files.
Workaround at the moment is to import the CSV to a spreadsheet program first and reformat the dates to mm/dd/yyyy
Thanks @david I’ll check out the link you provided. I’ll see if I can find a script that can change the date format in my CSV files before importing. Unfortunately that’s the way the bank outputs these fields into CSV and I have no control over it.
