PHP 5.4.16 (cli) (built: Apr 1 2020 04:07:17)
Copyright (c) 1997-2013 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies
with the ionCube PHP Loader (enabled) + Intrusion Protection from ioncube24.com (unconfigured) v10.0.3, Copyright (c) 2002-2017, by ionCube Ltd.
But plesk always shows the default php with this command, when you setup a domain you choose which version of php, I also verified in my theme that i a running 7.3.27 and its set correct.
This issue happened all of a sudden, everything has been working fine for about a year or so.
I have solved the issue, for some strange reason my old crons stopped working, after many trial and errors for those trying to get a Plesk Obsidian cron working correctly for Version 4.5.38 (as the past posts I read were very unclear), here is the code:
Go to Admin/server/tools/ Schedule a Task (Cron jobs), click Add a Task, Choose Run a command, Add the code from below changing the php version, the sitename and the installation folder name) Set the time to run (24 hour clock) click OK
