Hello
I have been having a problem since softaculous preformed the upgrade from 2.4.8.1 to 2.5.1.3 on my self hosted install of Invocieninja.
My Cron jobs are not running and are generating the following errors.
PHP Parse error: syntax error, unexpected ‘class’ (T_CLASS), expecting identifier (T_STRING) or variable (T_VARIABLE) or ‘{’ or ‘$’ in /home/driveshare/public_html/portal/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php on line 146
I have set my PHP version in cpanel to use PHP 5.5, and I know this is working because It breaks my website that only supports PHP 5.4.
I get the same error when running the artisan ninja:send-invoices or artisan ninja:send-reminders command via SSH
My Cron jobs are set to run at 4am everyday and have not had a problem until after the upgrade.
/usr/local/cpanel/3rdparty/bin/php /home2/driveshare/public_html/portal/artisan ninja:send-invoices
/usr/local/cpanel/3rdparty/bin/php /home2/driveshare/public_html/portal/artisan ninja:send-reminders
Any Help would be greatly appreciated as I am completely lost as how I need to tackle this.
Kind Regards
Cyberone
