Cron jobs not working for my crm
Hello there is a problem in running cron jobs can you help me out
This is my website crm.phlera.com
Thank you
Are you seeing a specific error?
No just the red error triangle and reminders are not sent
Have you configured the cron?
Yes
You need to update /path/to/root/folder in the cron
Do you mean like this
The screenshot above has both
Should i remove all others?
It’s hard to tell what I’m looking at, you should only need one schedule:run cron
