After installing, I just rewalized that though the CRON job was setup, it was erroring out on the shared host I’m with. After chatting with support, it appears they can call a file, but not the subsequent commands, so the cron job was failing.
In looking at the help documents I see the following…but Im not sure exactly to do with these instructions:
If you server doesn’t support crons commands can be run by setting a value for COMMAND_SECRET in the .env file and then loading /run_command?command=<command>&secret=<secret>. The following commands are supported: send-invoices, send-reminders and update-key.
I tried adding the COMMAND_SECRET to the envelope file, but im not sure ive formatted it correctly, snd see no documentation on how to set it up.
