Hi all,
I just updated to v5.3.29-C62
Ubuntu 20.04.3 LTS
When I create an invoice, it gives me error 500, but it creates the invoice.
Hi all,
Ubuntu 20.04.3 LTS
Are there any details about the error in the logs in storage/logs
I had to revert the changes, so I can use it.
I didn’t find any errors in the logs.
Ok, FYI… if reverting the code fixed it it could be that the migration didn’t run. You can run them manually from the command line using php artisan migrate
so I do the update then run this command
php artisan migrate
did I get it right?
After you run the upgrade the app should automatically run the migrations.
If the migrations fail you may see a 500 error in which case manually running them can help.
In all cases there may be useful info in the logs in storage/logs.
it gave me same error, both logs listed
root@infra:/var/www/html/ninja5/storage/logs# cat laravel.log
[2021-10-28 16:24:29] production.ERROR: Cannot update system because services.php is not writable {“userId”:1,“exception”:"[object] (App\Exceptions\FilePermissionsFailure(code: 0): Cannot update system because services.php is not writable at /var/www/html/ninja5/app/Http/Controllers/SelfUpdateController.php:104)
#0 /var/www/html/ninja5/app/Http/Controllers/SelfUpdateController.php(65): App\Http\Controllers\SelfUpdateController->testWritable()
#1 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\SelfUpdateController->update()
#2 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#3 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(261): Illuminate\Routing\ControllerDispatcher->dispatch()
#4 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(204): Illuminate\Routing\Route->runController()
#5 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Routing\Route->run()
#6 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#7 /var/www/html/ninja5/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#8 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle()
#9 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#10 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#11 /var/www/html/ninja5/app/Http/Middleware/Locale.php(34): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#12 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle()
#13 /var/www/html/ninja5/app/Http/Middleware/PasswordProtection.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\PasswordProtection->handle()
#15 /var/www/html/ninja5/app/Http/Middleware/TokenAuth.php(80): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\TokenAuth->handle()
#17 /var/www/html/ninja5/app/Http/Middleware/SetDb.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDb->handle()
#19 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest()
#21 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#22 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\Pipeline\Pipeline->then()
#24 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\Routing\Router->runRouteWithinStack()
#25 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute()
#26 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute()
#27 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#28 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#29 /var/www/html/ninja5/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(55): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#31 /var/www/html/ninja5/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#33 /var/www/html/ninja5/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle()
#35 /var/www/html/ninja5/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#37 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#39 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#40 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#42 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#43 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#45 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#47 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#49 /var/www/html/ninja5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#50 /var/www/html/ninja5/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#51 {main}
root@infra:/var/www/html/ninja5/storage/logs# cat invoiceninja.log
[2021-10-28 16:24:29] production.INFO: Cannot update system because services.php is not writable
this is just before the upgrade
You’ll need to chown everything to the webuser.
You’ll see this error if you run php artisan optimize
as a user that isn’t the webuser.
that fixed it
the errors in the beginning of the logs are before the update
