I’d trying to create a project via API, and want to set more than just the client_id and name. At a minimum I think I should be able to set the task_rate and budgeted_hours. Nothing I’m doing is working though to get those other fields through, the first two, if alone, work fine.
Is this simply not available, or do I need to do something differently? Thanks!
me@me ~ % curl -X 'POST' \
'https://_url_here_.com/api/v1/projects' \
-H 'accept: application/json' \
-d 'client_id=IelazUdJ2&name=tester testerson&budgeted_hours&10&task_rate=50.00' \
-H 'X-Api-Secret: password' \
-H 'X-Api-Token: _long_ol_token_here_' \
-H 'X-Requested-With: XMLHttpRequest';
