Hello
I’m wondering if it is possible to configure the system to by default when you send a invoice that a CC copy is also sent to email address for internal records?
Was this Feature removed in the newer Versions? I have invoice ninja installed via docker, with Version 5.8.37 but could find any settings regarding Global cc or bcc. Only on each Individual customer.
Ok i discovered that i cannot set BCC when SMTP is selected for the email client.
When i set it to Standard the BCC field shows up. But then my emails don’t work anymore.
BCC is (In general) a bad idea to use anyway because it has been used and abused by spammers for many years; so actually loads of e-mail servers will treat e-mails with hidden e-mail addresses (The BCC field), as spam by default.
So per see it is not really recommended to use BCC and mail deliverability will drop/not always be stable.
Obviously a shame because BCC is indeed quite a useful feature sometimes. But this is just how the world looks and we cannot change it.
By the way @hillel…
This (The above I just wrote about BCC), is actually my initial reasoning for asking about a CC field instead, because BCC is “problematic” to use and will not always work.
