I would like to contribute to the react ui. The repository is forked and up to date in my CodeSandbox. After running npm run dev I see the login page, but cannot login.
Could you give me little assist on how to setup the url to my instance or to a demo instance?
Your welcome! I cannot promise that I make goals… But I will try… So in the meantime I found the setting to connect from CodeSandbox to my own InvoiceNinja Instance… It works now…
I looked too far, while the solution was directly in front of my nose So no need to assist for the moment…
I simply put my InvoiceNinja-URL to the .env-File (VITE_API_URL).
