Hello Im looking for a templte for contacts upload so I don’t have to adjust fields for each contact, I will need it for the Spanish version interface.
Tanks
Daniel J.
Tanks
Daniel J.
After you upload the file the app enables mapping the columns to fields.
Note: the app is limited to importing one contact with each client.
Really?.. so the import drop-down option ¨CSV¨ is to import individual contacts? cannot do bulk import?
What other options are available to do bulk imports?
What about if Im importing from any of the services listed on import drop-down these allow bulk imports?
Daniel J.
It bulk imports clients, each with a single contact.
You could use a tool like Zapier or Integromat.
