Configure system to send emails immediately?
Hi
I just wonder if it is possible to configure the system to send invoices directly instead of a scheduled time?
Also in regards to cron:
https://invoice-ninja.readthedocs.io/en/latest/configure.html
It is possible to call the cron jobs from the web instead with a service?
Example:
Thanks in advance
AngryWarrior
One option may be to use the reminder feature and set the number of days to zero.
There’s info about using a web cron here:
https://invoiceninja.github.io/docs/self-host-troubleshooting/#webcron-configuration
Thanks @hillel I’ve setup that in the past.
So it seems to be working fine, right? :smiley:
Sorry maybe I didn’t express myself clearly.
I mean does the cron job also include cron for invoices etc?:
Thanks in advance
Kind regards
AngryWarrior
That screenshot if for the v4 docs, I believe in v5 you only need to call the main web cron.
So you do not need several crons anymore?
Kind regards
AngryWarrior
That is correct, in v5 just one cron is needed
Thank you Hillel. :+1:
Kind regards
AngryWarrior
