Is it possible to use set default footer fo all the invoice from Company Details > Defaults > Invoice Footer.
Attempted $company.invoice_footer, $company_invoicefooter and doesn’t seem to work. Anyone can advise?
Regards,
Hari
Regards,
Hari
@hillel,
Thanks.
I believe this is from individual invoice footer. I recall the default we specied will be automatically copied in to any invoice we create and the users are able to append / replace that is specific to the invoice. That doesn’t seem to be the behaviour in V5. Is it?
Regards,
Hari
I believe that’s how v5 should work.
The default is used when initially creating the invoice but can be later changed.
Got it now. I made a mistake. Thanks.
