I am using a self-hosted v5, and currently setting it up. It’s really great.
I am wondering if I can set up a common counter for my user. The reason is that I am using two brands for one company:
Company A
=> Brand X (sells via website to consumers) → invoices generated via API from website
=> Brand Y (sells to companies) → invoices generated manually in InvoiceNinja
=> one common counter ?
In order to get correct branding, I have set up Brand X and Brand Y as 2 separate companies under one user.
Is there a way these 2 “virtual companies” can share one counter ? From what I understand, none of the current options apply, but I think this could be useful.
I think this may be a good example of us making the common easy and the uncommon possible. This isn’t a standard setup but the flexibility v5 provides should support it. If you have any trouble getting it working let us know.
