Column headings
Is there a way to adjust the texts of the column headings to shorten them?
Sorry, it isn’t supported. Are these custom fields?
These are default fields of the system.
What does it translate to in English?
I have changed the text under “/lang/en/texts.php”, but this does not change the column heading. In which file can the text be customised?
You would need to rebuild the app.
