Hi All,
new here and new to invoice ninja. had to fiddle around quite a bit during setup but all working now - amazing job with this software!!!
- I’ve noticed (as per the title) in the client area everything is viewable except for quotes.
It happens when you click on the “view” button on every quote - gives an error message of {“message”:“You are not authorized to view or perform this action”}
Invoices etc can be viewed - only seems to happen with quotes, I don’t think i’m the only one from looking at other threads but not seen just quotes.
I’ve tried disabling and re-enabling the module.
Refresh data and php artisan optimize…
Also have the red error triangle for cron jobs but they are set up on my cron jobs correctly as per the install. EDIT - This issue has been solved - must have been a time issue.
Have just noticed when on a client profile - if you click on client portal it gives a 404 not found - when I click on the back to my domain link it takes me to my domain/client which gives a warning of:
Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Not sure if these are bugs or if I’m doing something wrong
