Clientportal password and certificate
Good afternoon.
After quite some trial and error I have IN almost to my liking and needs.
I am not able to set up a password for the client portal though. When I check this in the settings (authorization) no password is accepted in the client portal (empty form returns) and clicking “forgot password” gives a 404.
When no password is required the portal is accessible but the browser tells me the connection is not completely safe, the certificate is ok though it says in the same pop up…
Any toughts?
It sounds like a proxy is in use? Would that be correct?
If yes, you will need to add
TRUSTED_PROXIES=*
in the .env file
Every day a small step further… Thanks…
