I’ve noticed that when I try to change “Client Settings” (When in the client mask → Settings) and try to change “Client Details” under “Invoice Design” any changes to the fields I make (e.g.deleting “Country”) do not stick.
You can check this in the web version (v5.4.12-C88) that when you make changes, the “Save” button does not become active as it does when you make changes in the “General Settings” tab of the “Client Settings/Invoice Design” form.
In the desktop app (v5.4.12-W97), the “Save” button is there and active, but when you hit save, the settings just revert to what you had before.
At the same time, since I use client settings, what I defined in the global settings (where changes are stored correctly) under “invoice design”, these settings do not apply for clients, who have separate settings.
Can others reproduce this? I’d think this is a bug.
Thanks,
Georg
HI - thanks for the pointer - I’ve tried it in the demo and it has the same behavior:
Click on any company (e.g. “1111” when I was in there today)
In the company view click on “Settings”
Under settings click on “Invoice Design”
In the invoice design mask, click on the “Client Details” tab
In client details field list click on any X in front of any field (e.g. Country) to delete it
Hi “Save” in the upper right
— boom, the filed you just removed is back again … nothing sticks!
My host didn’t have the gmp extension installed on PHP 8.1, which is why I still ran on 5.4.
Have meanwhile wrestled with them to open gmp also on PHP 8.1 and could update to v5.5.32-C98 through Softaculous - which runs without the json error that many describe when updating within the app.
But since the demo runs on v5.5.36-C99 and has the same issue, I think it’s not on my end.
Maybe the programming team can replicate and identify the issue at some point.
Hillel - I’m circling back to this post since I’m running into the issue again.
If the bug is that “the settings are shown” - what are the settings for in the first place?
The setting works perfectly fine for “Company Address” - e.g. adding or removing the field “Country” will reflect as such in the (invoice) preview.
Why can the same behavior not be achieved for the fields in “Client Details”?
Or maybe better, there should there be a tab with “Client Address”, which would work the same as the “Company Address” tab settings - i.e. allowing us to set what should be shown in invoice designs when we enter the variable “$client.address”
Nevermind — I found a workaround creating an invoice design that doesn’t use the $client.address variable but rather use the individual field variables $client.name, $client.address1, etc.
So back to the settings - maybe the tab “Client Details” should be removed if it’s not used anywhere. But it could still be that I’m missing something here where those are actually used.
