Client Registration Page not working
Good Day Everyone.
The client registration field for my docker instance does not work. I read and found that I need to add data to my database (But I do not know what I am doing). I am currently running a MariaDB.
I connected to the DB via ubuntu command line but I am having issues finding the correct command line to type in. Can anyone just help correct me:
INSERT INTO companies (client_registration_fields) values (‘[{“key”:“first_name”,“required”:true},{“key”:“last_name”,“required”:true},{“key”:“email”,“required”:true},{“key”:“phone”,“required”:false},{“key”:“password”,“required”:true},{“key”:“name”,“required”:false},{“key”:“website”,“required”:false},{“key”:“address1”,“required”:false},{“key”:“address2”,“required”:false},{“key”:“city”,“required”:false},{“key”:“state”,“required”:false},{“key”:“postal_code”,“required”:false},{“key”:“country_id”,“required”:false},{“key”:“custom_value1”,“required”:false},{“key”:“custom_value2”,“required”:false},{“key”:“custom_value3”,“required”:false},{“key”:“custom_value4”,“required”:false},{“key”:“public_notes”,“required”:false},{“key”:“vat_number”,“required”:false}]’);
@Surgit
If you have command line access try this:
php artisan tinker
\App\Models\Company::query()->update(['client_registration_fields' => \App\DataMapper\ClientRegistrationFields::generate()]);
@david
No Luck. Sorry I am not clued up with regards to Accessing any MySQl database.
Below is example of how I connected to the database via Command Line (If it helps):
mysql -h 166.78.144.191 -u username -ppassword database_name
@Surgit
This isn’t a command to execute in mysql, if you navigate to the root directory of the project. then type those two commands.
php artisan tinker will open a direct DB connection via Laravel, and the next statement injects the required fields into the database for you.
Issue solved. Thanx David
For anyone else having a similar issue:
If your running Invoice Ninja via Docker. Access the container via the following:
sudo docker exec –it /bin/sh
As David mentioned type:
php artisan tinker
then:
\App\Models\Company::query()->update([‘client_registration_fields’ => \App\DataMapper\ClientRegistrationFields::generate()]);
Restart the containers and your Registration page should work as intended
