See screenshot. Clicking on the Client Portal button there doesn’t do anything.
Are you using the web app or the desktop app?
Does it help to select the details tab and then click “View portal”?
Web app.
Yes, the VIEW PORTAL button on the details tab does work.
Thanks for the info!
Does the problem affect all clients?
I checked a bunch and none of them worked.
Thanks, we’ll look into the problem
