Trying to reset a client’s password and done the following steps:
Manually sent a reset link to email address via filling out the forgot password form (Failed token invalid or session expired messages)
Tried to edit client via management interface… failed… no field visible to reset users password manually in the “edit client” page.
Any hint’s because i’m now at a loss at what should be a basic task.
Hmm ok guess i need to do a bit or client side testing to understand.
So my question is as follows:
Joe Blogs decides to check on his payment history, he goes to my portal that asks for a email address and password… but he dosnt have a password for his account and resetting it dosnt work…
I am having this same issue as described Here.
I am currently on the new 4.5.17 White Labeled
1st there is no option in my admin panel to add a client password or change the client password.
So the method to let the client login is to send them the first invoice.
There is a link in the invoice email they get.
The client clicks the link to the invoice.
This opens the clients web browser to our client portal.
It wants there username and password.
New clients I just tell them to click forgot password, then they can enter there email address to reset there account.
They click on forgot password enter in there email address and they click reset password.
This gives the client an email for password reset.
The client then clicks the link.
The system opens a new web page asking for an email address and a new password and to confirm the new password.
They click submit and the system instantly displays an error: The security token has expired please login again.
it does not take them to the dashboard or tell them the password has been reset just an error.
However it does process the password change and they can login with the password just not very user friendly.
I have searched the forms and there is another mention of this however it is not fixed in my current version.
Thanks again
Steven
Thank you for such a quick reply.
I have looked everywhere for this and have not found it.
I have attached my back-end images
Am I in the wrong area?
Thanks again
Steven
Password Protect Invoices (Assumed this was so that each invoice is password protected.)
NOT CHECKED
Allows you to set a password for each contact. If a password is set, the contact will be required to enter a password before viewing invoices.
Generate Automatically
NOT CHECKED
Ok just to make sure which one of those would I enable and will this require each invoice the customer views to require a password or will it just make it so that the client requires a password to login to the customer portal?
Like it currently does?
Thanks again
