We have several invoices that were originally scheduled to send out on the 17th of each month. A couple months ago we had some server problems and somehow those recurring invoices started sending on the 22nd of the month.
They now say ‘Send Next: June 22, 2016’.
Is there any way that I can get these to send on the 17th again? (for this month and all future months)
Or do I have to just cancel the old one and create a new recurring invoice?
THANKS! That ‘almost’ solved the problem (well, it solved the problem based on the incident I mentioned).
Just in case someone needs to reset the date to TODAY:
IF you reset the start date for today but your cron job runs overnight (i.e. which would be the next calendar date), I don’t think that IN will send out those invoices (because it appears to only send out the invoices for the current date - and in this case the date for today will have already past).
The solution I found was to:
Change the start date (as originally indicated)
Send the invoice manually
That makes sure that the invoice gets sent on this date.
This would probably only be a limitation if you are running your cron just once a day. If your cron runs more often I would expect that you would be fine with just step 1 above.
THANKS for a GREAT system and great support when needed!
