Is it possible to change the client portal URL? Right now it is set to example.com/client but I want to change that to client.example.com . I can try do do it with a rewrite rule, but maybe I run into problems.
I don’t believe this supported in the app yet, you can track the feature request here:
opened 09:42PM - 09 Mar 21 UTC
feature request
**What version of Invoice Ninja are you running? ie v4.5 / v5**
v5.1.16
**What… environment are you running?**
ZIP
**Have you searched existing issues/requests?**
yes
**Additional context**
Since the client portal is essentially separate web app, it would be great to have the option within UI settings of configuring client portal at a different domain, i.e. I have my site at billing.example.com, client logs in at billing.example.com/client. But I don't want my company portal login domain exposed so I would rather put the flutter app under random-string.example.com and client under billing.example.com/client or /pay.
Once I can configure within the client portal app a domain name/url, it should be possible to point apache/nginx config for that domain name to to the client portal app's directory as that domain's web root.
Thanks, it didn’t come up in my search. I will support and track the request.
