So yea,
Im selfhosting invoiceninja.
It says that its missing zip extensions but i have enabled it. What to do?
https://gyazo.com/447a2f13b49768b88b42d7bf4b2e2b4c
https://gyazo.com/1f4e9f4ce71740f1cef2a77b9dc925a9
That error is quite absolute. It means that the zip extension is not available at runtime for the PHP vesion that is being executed.
It shows your current PHP version is 8.0 on your PaaS screenshot. You should use 7.4 instead. I have to use 8.0 for a Grav blog on my server, and I have to use 7.4 for Invoice Ninja v5.
