Cant get spacing or paragraphs in product description
cant get spacing or paragraphs in product description, its all one long sentence, single paragraph
is there any way to speak to a human? 780-880-8866
HI,
It sounds like the markdown feature is enabled. You can either disable it on Settings > Account Management or use two line breaks to create separate paragraphs.
