I just tried to update my connection with Zapier and now I can’t get anything to connect. Zaps are failing left and right now and I really need help ASAP.
I understand that we may need to upgrade to v5 but I’m nervous to update it as we have several endpoint subscriptions that I’m not sure if they will be harmed if we migrate.
Thank you for that. I do have one final question pertaining to v5…
Are there any differences in how the API works? We are sending data to and receiving data from invoice ninja and want to make sure that if we migrate we don’t need to change anything beforehand.
Specifically, will creating an invoice through the API change?
