Hi
Hope someone can help …
Just installed v5.5.48 and got it up and running but as i want to change currency (not a lot of options in dropdown) it blanks out.
NO ERRORS INLOG FILE !!
Please help !!
Hi
Please help !!
Nevermind … FIX it. Did a forced update and it resolved the problem … Thanks
I have the same issue, how did you do the update?
I use a docker installation.
