Help please!
I cannot attach documents via the API in v5.
Documentation says to format attaching documents as follows:
curl -X POST https://invoicing.co/api/v1/invoices/ <invoice_id>
-H ‘Content-Type: multipart/form-data’
-H ‘X-API-TOKEN: TOKEN’
-H ‘X-Requested-With: XMLHttpRequest’
-F _method=PUT
-F ‘documents[]=@filename.png’
I need to do this via python and have the following code.
import requests
invoice_id = 'pmbkJqAvaz'
file = 'https://pdf-temp-files.s3.amazonaws.com/c4614a7a83de4972a1a5e5adad1668f8/time_sheet.pdf'
headers = {
'X-API-TOKEN': '7KZ09cUvsfdeVpMraynSCJEzuOOqkambGTKdyUZR4zTSMtzfbJWBS7KPgGCd6NBc',
'X-Requested-With': 'XMLHttpRequest',
files = {
'_method': (None, 'PUT'),
'documents[]': file
response = requests.post('https://invoicing.co/api/v1/invoices/'+invoice_id, headers=headers, files=files)
response.status_code
I get a 200 response code and see that the document is attached to the invoice
HOWEVER when I try to view the documents, the only thing that opens is a text page showing the URL
https://invoicing.co/documents/3uDs4xJ154Av8eZl1poR9udHL7OUTCa91uJ9cpHc.txt?inline=true
I know that I’m missing the ‘Content-Type’:‘multipart/form-data’ header, but every time I try to pass it in I get the following error ‘{“message”:“Method not supported for this route”}’
I also can’t manually upload documents at all, as every time I click the button it doesn’t do anything.
What am I doing wrong here?
December 5, 2021, 7:19am
@david can you spot any problems?
david
December 5, 2021, 10:45am
3
which docs are you looking at?
from my reference i see the following should work
curl -X POST
http://ninja.test:8000/api/v1/invoices/1YQdJ2dOGp/upload
-H ‘X-API-TOKEN: token’
-F _method=PUT
-F documents=@/home/david/settings.txt;
@david Docs I’m referencing are Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja
The example given in the docs for attaching invoices is also different from what you are sharing here. You say that your code “should work” but I really need a verified example.
Are you able to provide me the true working example of how to attach documents? I keep trying all different variations and nothing seems to work.
david
December 6, 2021, 4:05am
5
@zmccarty56
The example in the docs is missing the /upload in the route, i’ll adjust this now, i’ve tested the following as working correctly.
curl -X POST 'http://ninja.test:8000/api/v1/invoices/l4zbq2dprO/upload' \
-H 'Content-Type: multipart/form-data' \
-H 'X-API-TOKEN: company-token-test' \
-H 'X-Requested-With: XMLHttpRequest' \
-F _method=PUT \
-F documents[]=@/home/david/upload.txt;
Can you confirm that the URL should be
https://invoicing.co/api/v1/invoices/ <invoice_id>/upload
I noticed you have http in your example
david
December 6, 2021, 4:40am
7
yes, for our hosted platform, you would use
https://invoicing.co/{invoice_id}/upload
So the url doesn’t need /api/vi/invoices???
I’m very confused, as the working example you showed me has a full url containing /api/invoices/<invoice_id>
But then you followed up and didn’t include those values? What is the correct url for a v5 document upload on hosted.
david
December 6, 2021, 7:44am
10
curl -X POST https://invoicing.co/api/v1/invoices/<invoice_id>/upload \
-H 'X-API-TOKEN: TOKEN' \
-F _method=PUT \
-F 'documents[]=@filename.png'
This used to work fine using zapier in v4. Why can I not get this working at all even while using curl in v5?
I got the command working in curl just fine, but I need to convert it into a python request.
Do you have the ability to help me do this? Or can point me in the right direction to a resource? I’m trying to upload the document that I don’t have stored locally as it’s from a url
import requests
headers = {
'Content-Type': 'multipart/form-data',
'X-API-TOKEN': 'WLEyIKsii8JHPPOY4MGBEuEzjDY15A8Gcg71DXPraodGtahgtrMXL7HYG2C40Lzj',
files = {
'_method': (None,'PUT'),
'documents[]': 'https://pdf-temp-files.s3.amazonaws.com/ae7f9005db69425a874e5b2e003b9e59/time_sheet.pdf'
response = requests.post('https://invoicing.co/api/v1/invoices/pnelKrqVdKz/upload', headers=headers, files=files)
response.json()
david
December 10, 2021, 8:37pm
15
What response are you getting back from the server?
Also, are you able to reference a remote file that that in the request?
@david I’m getting back “Method not supported for this route”
david
December 14, 2021, 5:01am
17
@zmccarty
can you try changing requests.post
to requests.put
New error I’m getting is {‘message’: ‘No query results for model [App\Models\Invoice].’}
@david
Here is where my code is at
import requests
headers = {
# Uploaded document name
remote_name = 'https://pdf-temp-files.s3.amazonaws.com/ae7f9005db69425a874e5b2e003b9e59/time_sheet.pdf'
# Name/path of the document on your local machine
local_name = "time_sheet.pdf"
# Now the put data, `open` the local file.
files = [ ("file", (remote_name, open(local_name, "rb"), "application/pdf")), ]
response.json()
One thing I’m concerned about is even if I exclude the document entirely and just try to run a post request with headers and url, I still get the Method not supported for this route error
So there is something outside of the file that isn’t working
david
December 14, 2021, 6:09am
22
Are you sure that Invoice exists?
