Hi.
I just updated to latest version .56 and can not switch between companies anymore. Cleared the cache and health check is OK.
It will say Please wait fir the data to finish loading.
Any ideas?
Thank you
Br,
Dali
Hi.
Any ideas?
Thank you
Br,
Dali
It may help to login again by loading the site with ?clear_local=true
at the end of the URL
does not help.
Also when I press Clear cache inside Health check in will result in endless Loading.
Luckily I made VM snapshot so I can revert back to version .54.
Br,
Dali
Well, today for .57 it works OK. Have you change anything? Yesterday I updated it 4 times (reverting before update VM snapshot) and I always got the same issue.
Thank you
Br,
Dali
Thanks for the update, unsure what the issue was, but good to hear it is resolved for you.
