I have over 100 recurring invoices that were created before I discovered the :YEAR+1 variable. Can I do a SQL mass update just to change the description in the recurring invoices and will the recurring invoices respect the :YEAR+1 I.E Will it create the invoices and have the year plus 1 in the generated invoice?
Failing that I will have to manually edit every recurring invoice.
OK. If the variable is processed when the invoice is created then I should be OK to change the description with SQL command as the recurring invoice is already set up in the system. I am only changing a text field and not an index field to another table.
