Bugreport for v5.5.103-SC113
Suppliers are no longer displayed.
I’m not sure what you mean by suppliers, do you mean transactions?
Can you check the module is enabled on Settings > Account Management.
Sorry, I found the mistake. It is just a missing translation in the current version. Therefore, it now says “vendors” instead of “Lieferanten”.
I think this will need to be corrected in Transifex.
What means “Transifex”?
