Ephen
December 26, 2022, 2:27pm
#1
Hi, I don’t know why I can’t access my page with the link, it shows me a blank page which makes me can’t login but everything is fine on app.
P.s. This issue was happened after I customise the Quote and Invoice Template
Any idea to solve this problem? I don’t want to reinstall the system, thanks.
December 26, 2022, 2:43pm
#2
Do you mean the client portal is blank?
Ephen
December 26, 2022, 2:47pm
#3
No, my admin panel is blank, the client panel is normally working
December 26, 2022, 3:55pm
#4
Ephen
December 27, 2022, 12:59am
#5
No error occurs, it just shows me a blank page
December 27, 2022, 6:06am
#6
Are you familiar with the browser console?
How to find the browser developer console in Safari, Chrome, Edge, IE, and Firefox.
Ephen
December 27, 2022, 7:52am
#7
DevTools failed to load source map: Could not load content for chrome-extension://eppiocemhmnlbhjplcgkofciiegomcon/ad-blocker/panelos-content.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
DevTools failed to load source map: Could not load content for chrome-extension://eppiocemhmnlbhjplcgkofciiegomcon/content/safecheck-notification/serialization.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
DevTools failed to load source map: Could not load content for chrome-extension://eppiocemhmnlbhjplcgkofciiegomcon/content/serialization.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
DevTools failed to load source map: Could not load content for chrome-extension://eppiocemhmnlbhjplcgkofciiegomcon/content/app-notification/serialization.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
It only shows me this
December 27, 2022, 8:00am
#8
Can you check what set_react_as_default_ap is set to in the account table?
If you’ve enabled the React web app you can change back to the Flutter web app using this SQL query:
Ephen
December 27, 2022, 1:40pm
#9
I tried to update that via query but the page is still blank and no error occurs
December 27, 2022, 1:43pm
#10
Do you see any errors in the logs in storage/logs?
Can you use the view source option and share the first few lines of the file?
Ephen
December 27, 2022, 3:07pm
#11
[2022-11-24 04:15:13] production.ERROR: Call to undefined function Symfony\Component\Console\proc_close() {“exception”:"[object] (Error(code: 0): Call to undefined function Symfony\Component\Console\proc_close() at /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Terminal.php:164)
#0 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Terminal.php(142): Symfony\Component\Console\Terminal::readFromProcess()
#1 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Terminal.php(108): Symfony\Component\Console\Terminal::getSttyColumns()
#2 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Terminal.php(91): Symfony\Component\Console\Terminal::initDimensionsUsingStty()
#3 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Terminal.php(48): Symfony\Component\Console\Terminal::initDimensions()
#4 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/symfony/console/Application.php(140): Symfony\Component\Console\Terminal->getHeight()
#5 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/laravel/framework/src/Illuminate/Console/Application.php(102): Symfony\Component\Console\Application->run()
#6 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/laravel/framework/src/Illuminate/Console/Application.php(194): Illuminate\Console\Application->run()
#7 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(336): Illuminate\Console\Application->call()
#8 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(338): Illuminate\Foundation\Console\Kernel->call()
#9 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/app/Http/Controllers/SetupController.php(309): Illuminate\Support\Facades\Facade::__callStatic()
#10 /home/innoplfn/domains/invoice.innoplanet.hk/public_html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\SetupController->update()
Do you mean this?
December 27, 2022, 3:09pm
#12
Are new errors generated when you refresh the web page?
Ephen
December 27, 2022, 3:28pm
#13
There are no new errors generated and I am not sure do you mean this:
Invoice Ninja
Ephen
#14
<html data-report-errors="0" data-rc="" data-user-agent="Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36" data-login="false">
<head>
<!-- Source: https://github.com/invoiceninja/invoiceninja -->
<!-- Version: 5.5.41 -->
<meta charset="UTF-8">
<title>Invoice Ninja</title>
<meta name="google-signin-client_id" content="">
<script type="text/javascript" nonce="0078c20bb4f84a439c51d1fd2c6" src="//local.adguard.org?ts=1672152790160&type=content-script&dmn=invoice.innoplanet.hk&pth=%2Fpublic%2Findex.php&app=com.brave.Browser&css=3&js=1&rel=1&rji=1&sbe=1"></script>
<script type="text/javascript" nonce="0078c20bb4f84a439c51d1fd2c6" src="//local.adguard.org?ts=1672152790160&name=AdGuard%20Extra&type=user-script"></script><link rel="modulepreload" href="/react/is-buffer.f91fab60.js">
December 27, 2022, 3:33pm
#15
Thanks! Have you tried with more than one browser?
Ephen
December 27, 2022, 3:34pm
#16
Yes, I tried Brave and Safari
December 27, 2022, 3:35pm
#17
You could try switching to the React app to see if it helps:
UPDATE accounts SET set_react_as_default_ap = 1;
Ephen
December 27, 2022, 3:37pm
#18
seems not working, it keep showing me a blank page
December 27, 2022, 3:41pm
#19
@david do you have any ideas?
Ephen
December 27, 2022, 3:43pm
#20
I’m curious why only the web version doesn’t work
