basic markup syntax won’t work anymore in V4.01:
Header
Small text
bold
italic
bold
italic
I"m not sure, it seems to work in my tests.
Hi Hillel,
not in my case…
In the 3.X Version it worked for me, but in the V4 self hosted version the same syntax just prints in the PDF preview the ### out
I tried it in the invoice item description Field
If you want to email a sample ‘view as recipient’ link to contact@invoiceninja.com I can try to debug it.
Thanks for your help!
Problem was, that the Basic Markup Syntax Needs a linebreak before the Markup:
Example 1 (not working)
normal text ### small text
: works not, because linebreak is missing
Example 2 (works fine)
normal text
### small text
: works, because of linebreak before the Markup
