Does the bank integration feature work in the self-hosted (dockerized) version of Invoice Ninja? I can’t seem to find the Connect button in the Bank Account settings screen.
You can import bank transactions as CSV but the selfhost app doesn’t support a direct connection using Yodlee. Their pricing starts at $500 a month.
Thanks @hillel I just noticed the headline in the email that was sent out to subscribers which says NEW Enterprise Feature!
Just saw this issue, maybe Nordigen is an option?
Thanks @hillel Unfortunately the service is only available for European and UK banks, but thanks for the suggestion. I’ll keep looking, and just use the manual method of importing CSV files in the meantime.
