Just to add to what Hillel said, if you’re using the current version, it will visit ninja.url/update automatically (if you don’t have UPDATE_SECRET set in .env), to keep from introducing problems between copying the files over and when you actually go to login the next time.
Also, you don’t technically have to have an extension on the file, as long as it has execute permissions set. I just set chown to root:root, and set the permissions to 774.
There ARE a couple lines in there (64 and 83, then comment out 84, if I remember correctly off the top of my head) to utilize the UPDATE_SECRET variable in the .env, but I have yet to sort out some strange issues where loading ninja.url/update?secret=<somevalue> fails on the first attempt, but works fine on the next, so use that at your own risk. Once I can figure out what’s going on with that, the next version of the update script will be completely automatic. It will find your Invoice Ninja install, double-check the proper owner of /var/www/ninja/storage, whether or not you’re using UPDATE_SECRET, etc.
Try removing line #8. I haven’t heard of it causing issues, but that #! that starts it might be confusing the system into thinking it’s a shell setting? It gets highlighted as one.
Just to make sure you got all the carriage returns, try running it through dos2unix just to be sure. Also, try setting the permissions to 775. I don’t THINK that lacking write permissions applies outside of the file itself, but giving it to the group anyway can’t really hurt.
I don’t see any errors in the logs. Assuming that replacing all the FTP files are replaced and I get past the 500 error, how would the new files know that I have an existing database/install to update, and am not installing a new ninjainvoice site from scratch?
Autoupdate:
My web host has confirmed that .sh files are not allowed to run due to security policy. I have changed the extension to .tct.
I am getting a different error now: version.txt not found. I’m pretty sure the file path is correct though, I have the autoupdate file in my public_html (root) and ninjainvoice in a folder (root/ninja) and I am using (/ninja) as ninja_home path.
My host does not allow dos2unix installation as I am on shared hosting.
If you’re unable to install dos2unix, you can do it the long way. First, use cat -v to check the file and see if the lines end in ^M or not. If they do, you can try
@Hillel, I wasn’t able to find the web server log files. By the way, I am accessing my server through cPanel and there is no /user/local folder in FTP.
@Titanfail, I checked that there were no ^M entries in the file, and had the username and permissions set correctly but the script couldn’t find version.txt
I decided to give up on autoupdates - my web host probably has multiple security policies blocking the script from running, since it is a shared server.
I reached out to support again regarding manual install, they did something with the files on their side and I was able to update successfully. I was told to contact support again whenever I needed to update as the fix was easier to implement for them than it is for me with my limited privileges.
I am trying to find out what the fix is so I can leave it as a comment here for anyone facing similar issues in future. At the moment, I know it is not permissions of file ownership related as those did not change.
Thanks to both of you for the awesome support! It totally made purchasing white label worth it, vs other competing web apps.
Depending on what you’re currently paying for shared hosting, the locked down account and need to contact support in order to update your install might mean a VPS would be a more cost-effective solution.
I followed manual update, copied new files over existing files to override all…i saw a popup saying my domain.ca says new update i should refesh so i did, i am on sign in page…i got 500 error too
2021/04/05 18:05:21 [error] 9155#9155: *3267 FastCGI sent in stderr: “Primary script unknown” while reading response header from upstream, client: 192.168.1.4, server:$erver: africana.ca, request: “GET /flutter_service_worker.js?v=5.1.26 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php7.3-fpm.sock:”, host: “africana.ca”, referrer: $rrer: “https://mydomain.com/flutter_service_worker.js?v=5.1.26”
this is my error log…i use a reverse proxy because i am testing invoice ninja on a test local server…whether manual update where i copy zip folder content from v5.1.35 to override the existing or i use force update in the login section, still get 500 error…
