I have two invoices that should have auto-paid yesterday (due December 1, and both customers have previously entered manual payments). The output from that day’s send-invoices task was:
2017-12-01 15:00:02 Running SendRecurringInvoices...
19 recurring invoice(s) found
Processing Invoice: 25
Sending Invoice
Processing Invoice: 37
Sending Invoice
2 due recurring invoice instance(s) found
Processing Autobill-delayed Invoice: 50
Processing Autobill-delayed Invoice: 51
0 recurring expenses(s) found
2017-12-01 15:00:35 Done
However, both invoices are still marked as unpaid. I’m using Stripe, and when checking my Stripe account, invoice #51 had a card-declined error (expired) and there’s nothing for #50.
How can I charge these invoices?
I opened up the “artisan” file and realized I’d be going far down an architectural rabbit hole, so I’m hoping I can get some help here instead.
On this note, what is the default for process for re-trying failed auto bill attempts? Does the system automatically try to re-bill daily? Is there a cron job I can run to re-try to run them?
ok. Would be nice feature to have a cron job that I could run daily to re-try payments. When you have 100 or so recurring payments, many fail for reasons. It would be nice to not have to manually re-try them.
We are self hosting. I am preparing for a class now, but will check the mail logs later today. Perhaps, the decline notices are getting held up somewhere.
The app is not sending notifications to the biller or client when client’s credit card is declined. I have checking the mail logs to make sure nothing was held up by a spam filter.
