Just wondering is it possible to automatically backup Invoice ninja from a hosted version?
Currently, I manually go into import/export within the windows application and i export the JSON file and store that.
I tried to add a schedule idea being that it would send a daily email of the backup and i would store these then from there. I tried adding a schedule but i dont seem to have an option to do it.
is very broad and it will widely depend on how you host it.
I am using K8s for instance so I backup using a Cron Job. While this is great for K8s users, it is mostly useless for others.
I just steup my backup and I am doing:
automatic mariadb-dumps
I use a separate volume mounted on /var/www/app/public/storage/backups so the generated backup do NOT land on the same volume where InvoiceNinja runs
I use a separate volume for /var/www/app/public/storage and that volume is backed up as well
Hopefully I did not miss anything
It would be nice however to have a single command that packs all of that together in an atomic way.
